[geos-commits] [SCM] GEOS branch 3.8 updated. 5ab6d2853877b4c917343dc35a4a5e3009b60289
Wed Jan 10 14:07:25 PST 2024
the project "GEOS".
The branch, 3.8 has been updated
       via  5ab6d2853877b4c917343dc35a4a5e3009b60289 (commit)
      from  a753ddf63f9168bc4cedf66e6d8a2c0753b3eaa9 (commit)
revisions in full, below.
commit 5ab6d2853877b4c917343dc35a4a5e3009b60289
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jan 10 14:06:45 2024 -0800
    Fix regression tests for AppleClang on ARM64
diff --git a/CMakeLists.txt b/CMakeLists.txt
index cd210afb2..bf9590f65 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -154,6 +154,20 @@ set(CMAKE_CXX_EXTENSIONS OFF)
 add_library(geos_cxx_flags INTERFACE)
 target_compile_features(geos_cxx_flags INTERFACE cxx_std_11)
+# Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
+# that allow it, as it breaks calculations in DD.cpp.
+# TODO: Replace DD calculations with 'long float' where target supports
+# true long float, and remove other cases where FMA causes regression
+# failures.
+#   https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98207
+target_compile_options(geos_cxx_flags INTERFACE
+	"$<$<OR:$<CXX_COMPILER_ID:Clang>,$<CXX_COMPILER_ID:AppleClang>>:-ffp-contract=off>"
+	"$<$<CXX_COMPILER_ID:GNU>:-ffp-contract=off>"
+	"$<$<CXX_COMPILER_ID:MSVC>:/fp:precise>"
 # Target geos_cxx_flags: common compilation flags
Summary of changes:
 CMakeLists.txt | 14 ++++++++++++++
 1 file changed, 14 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
