[geos-devel] Portability
Paul Ramsey pramsey at refractions.net
Fri Aug 30 15:10:22 EDT 2002
So, working through the compilation bit by bit, some problems seem to be:
- occasionally stdio.h is not declared where it is needed (maybe VC++
papers over this automatically)
- the compiler cannot find declarations for __min() and __max(),
although it *can* find declarations for min() and max(). What is the
difference between them? In GeometryCollection.cpp line 55, __max() is
used while an almost identical function just above it uses max().
P.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
