[geos-devel] Performance of GEOS
Norman Vine nhv at cape.com
Wed Nov 6 00:54:07 EST 2002
Martin Davis writes:
> Ok, let us know what you find out.
A little better - but not what I was hoping for
This is on a 733mhz PIII
Cygwin gcc 3.2
Norman
Code as in CVS
n Pts: 1000   Executed in 1000
# overlapping MCs: 44
# segment intersection tests: 4
n Pts: 2000   Executed in 4000
# segment intersection tests: 7
n Pts: 3000   Executed in 10000
n Pts: 4000   Executed in 22000
# segment intersection tests: 5
n Pts: 5000   Executed in 92000
n Pts: 6000   Executed in 156000
# segment intersection tests: 6
n Pts: 7000   Executed in 224000
n Pts: 8000   Executed in 315000
< manually stopped test before completion >
My test  code with no pure virtuals and inlined code
n Pts: 1000   Executed in 0
n Pts: 2000   Executed in 2000
n Pts: 3000   Executed in 4000
n Pts: 4000   Executed in 8000
n Pts: 5000   Executed in 16000
n Pts: 6000   Executed in 64000
n Pts: 7000   Executed in 110000
n Pts: 8000   Executed in 148000
n Pts: 9000   Executed in 194000
n Pts: 10000   Executed in 255000
