[geos-devel] Explicit exceptions in GEOS
Martin Davis mbdavis at VividSolutions.com
Thu Nov 14 19:40:07 EST 2002
Currently in the code there are all kinds of exceptions thrown which are simply strings.  We should replace these with an explicit exception class hierarchy.  As far as I know C++ doesn't provide any exception hierarchy by default, so we'll have to pretty much build our own.
I suggest at least the following:
GEOSException
	ArrayIndexOutOfBoundsException
	TopologyException
We can add others as needed.
The signature should look like:
GEOSException(char *msg);  // copies string
char *getMsg()
... maybe other stuff.  I have an existing Exception base class I can contribute - it's attached.
 <<exception.h>>
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street   Victoria, B.C.   V8T 5G5
Phone: (250) 385 6040    Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com  Web: www.vividsolutions.com
Type: application/octet-stream
Desc: exception.h
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20021114/915fd244/exception.obj
