[geos-devel] Portability
Yury A. Bychkov ybychkov at direct.ca
Sun Sep 1 05:24:07 EDT 2002
"Paul Ramsey" wrote:
> I should note that I did not work through everything until I got
> complete compilation. I just worked through a portion of geom. If I go
> through and commit changes which will allow compilation under GNU, would
> that be OK?
Sure, but it would also be very good if you can write down all the changes and
send them to me. This way I can avoid repeating them.
One note though: I am not sure that the version you are experimenting on will
compile even after you fix all incompatibilities. You should check out the
current version. I've just tested it and it should compile (I haven't committed
some of the incomplete files to ensure that). We also probably have to decide on
how to indicate it in the future versions. I frequently check in  files that are
incomplete (or have missing interdependencies) so that might be a common
problem.
Yury
