[geos-devel] About Compiling GEOS by MinGW
Hisaji Ono hi_ono2001 at ybb.ne.jp
Fri Apr 4 17:04:51 EST 2003
Thank you very much, Mr. Vine.
> This will have to wait for the GEOS namespace implementation
> as there is a confict due to MingW STL including <windows.h>
> which causes a conflivt with 'Polygon'
> Once the GEOS namespace is implemented you should be able
> to build GEOS with MingW by doing something like
> % CC="c++ -mno-cygwin" CXX="c++ -mno-cygwin" configure; make
