[geos-devel] Status (New Example)
Norman Vine nhv at cape.com
Sun Apr 6 21:28:35 EDT 2003
> > Curious ?
> Hum - there must be some difference between how linux and cygwin
> handle the
> communication between C and C++.  Perhaps there are some changes in the
> default options for gcc under cygwin??
> What version of gcc are you using?
3.2 but that shouldn't make any difference as this technique is identical
to that used by GDAL which AFAIK has had no problems reported
Norman
