[geos-devel] PostGIS CVS has GEOS support
Norman Vine nhv at cape.com
Wed Apr 9 15:52:10 EDT 2003
David Blasby writes:
> The PostGIS CVS now has GEOS support.
> Here's some instructions.  The Makefile is a bit "iffy" right now until
> paul takes a look at it.
> So if things dont work for you they should fix themselves in a few days.
>  USE AT OWN RISK.
attached diff for Makefile allows compilation with Cygwin
link order matters with Win32, ie,  symbols must be linked
after functions that use them. linked objects can be included
multiple times if necessary < -Wl,--allow-multiple-definitions >
haven't tried running it yet
Cheers
Norman
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030409/2f0d8f9f/diffs.obj
