[geos-devel] Error handling: GEOS throws in PostGIS.
David Blasby dblasby at refractions.net
Fri Apr 11 18:26:26 EDT 2003
I'm having troubles trapping exceptions thrown by GEOS in postgresql.
My GEOS wrapper (postgis_geos_wrapper.cpp) looks like this:
// call g1->contains(g2)
// returns 0 = false
//         1 = true
//         2 = error was trapped
char GEOSrelateContains(Geometry *g1, Geometry*g2)
    try {
        bool result;
        result = g1->contains(g2);
        if (result)
            return 1;
        else
            return 0;
    catch (...)
        return 2;
And in the .c PostGIS (postgis_geos.c):
// overlaps(GEOMETRY g1,GEOMETRY g2)
// returns  if GEOS::g1->overlaps(g2) returns true
// throws an error (elog(ERROR,...)) if GEOS throws an error
PG_FUNCTION_INFO_V1(overlaps);
Datum overlaps(PG_FUNCTION_ARGS)
    GEOMETRY        *geom1 = (GEOMETRY *)
PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
    GEOMETRY        *geom2 = (GEOMETRY *)
PG_DETOAST_DATUM(PG_GETARG_DATUM(1));
    Geometry *g1,*g2;
    bool result;
    errorIfGeometryCollection(geom1,geom2);
    initGEOS(MAXIMUM_ALIGNOF);
    g1 =     POSTGIS2GEOS(geom1 );
    g2 =     POSTGIS2GEOS(geom2 );
    GEOSdeleteGeometry(g1);
    GEOSdeleteGeometry(g2);
    result = GEOSrelateOverlaps(g1,g2);
    if (result == 2)
        elog(ERROR,"GEOS overlaps() threw an error!");
        PG_RETURN_NULL(); //never get here
    PG_RETURN_BOOL(result);
This works great in simple examples (like the test.c norman wrote).
But, when you have another layer of indirection - like with postgresql,
problems happen.  I think the problem is with postgresql loading a
C .so (postgis), which is linked to a C++ .so (GEOS).  Postgresql
is far removed from the GEOS error handling (in libc++).
Basically, as soon as "g1->contains(g2);" throws an error that leaves
the GEOS .so, postgresql dies immediately - the exception is not
catch so terminate() is called.
This doesnt happen if you are using GEOS in a c++ program, or using
a C++ wrapper for a C program. It only has problems with 3 levels
of indirection.
Others have had this problem - for example people writing PERL modules
that use the perl "C" api to call C++ libraries.  People doing the same
with PYTHON have also had problems. The only technical reference
I can find is at:
http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=37933
Basically, there's a problem if libc is loaded before libc++.
The only solution I can find to this (apart from forcing people to
use a very up-to-date gcc/g++ and perhaps statically linking libc++ to
postgresql) is actually write the C wrapper as part of GEOS.
In order to test this, I modified GEOS so that GEOMETRY has a function:
 void Geometry::throw_exception()
        throw "I see dead people!";
If you call g->throw_exception() in the postgis geos wrapper, postgresql
will immediately die.  But, if you re-write it (still in GEOS) like:
     try
         cout << "in throw_exception() try block - about to throw an
error"<<endl;
          catch (...)
              cout << "in throw_exception() - caught an error"<<endl;
              return;
          // never get here
You can successfully catch the error!
So, unless anyone has any bright ideas, we could think about putting a C
api directly in GEOS.  If we use the standard C way of error handling
(return an error code or NULL, like in the above), PostGIS should have
no problems.  Unfortunately, this does
"pollute" GEOS.
What think?
dave
