[geos-devel] CVS autogen.sh
Romi Hardiyanto rodin at unix.lib.itb.ac.id
Mon Apr 14 06:35:01 EDT 2003
Oops, sorry. Forgot to install one :) Thanks!
On Mon, 14 Apr 2003, Norman Vine wrote:
> Romi Hardiyanto writes:
> > Hi, i'm try to compile geos for university project i work on,
> > i'm using redhat 8.0, the autoconf-2.53 always complaining about
> > these macros:
> > configure.in:16: error: possibly undefined macro: AC_LIBTOOL_DLOPEN
> > configure.in:17: error: possibly undefined macro: AC_LIBTOOL_WIN32_DLL
> > configure.in:18: error: possibly undefined macro: AM_PROG_LIBTOOL
> Do you have libtool installed on this system ?
> > Cygwin autoconf is ok (using autoconf 2.52), but i always get errors when
> > linking objects: libtool seems doesn't pass -lstdc++ 'gcc -shared'.
> > any ideas?
> this is a known problem with Cygwin libtool :-(
> Explicitly set LD
>  'configure LD=g++'
> HTH
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
