[geos-devel] GEOS on Solaris?!
Carsten Neumann CarstenNeumann at web.de
Wed Apr 16 16:45:42 EDT 2003
Hi!
Sorry, but I haven't had the time to answer earlier.
I have tried debugger on the examples but it doesn't start because there is
no real executable.
If I start the script, I'm getting:
bash-2.03$ /home/neumancn/nexus/src/gdb-5.3/gdb/gdb SimpleWKTTester
GNU gdb 5.3
Copyright 2002 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as
"sparc-sun-solaris2.8"..."/home/neumancn/nexus/src/ge
os/source/test/SimpleWKTTester": not in executable format: File format not
recog
nized
(gdb) run
Starting program:
No executable file specified.
Use the "file" or "exec-file" command.
If I try the objectfile, the result is:
bash-2.03$ /home/neumancn/nexus/src/gdb-5.3/gdb/gdb SimpleWKTTester.o
GNU gdb 5.3
conditions.
This GDB was configured as "sparc-sun-solaris2.8"...
(gdb) run
Starting program:
/home/neumancn/nexus/src/geos/source/test/SimpleWKTTester.o
Warning:
Cannot insert breakpoint -1.
Error accessing memory address 0xe0: I/O error.
The same program may be running in another process.
So what command should I try?
Carsten
