[geos-devel] Status
Paul Ramsey pramsey at refractions.net
Mon Feb 17 11:41:07 EST 2003
Thanks for the update Yury! Keep them coming... sounds like a good plan
of work. Be sure to advise the list when you think you've got a
compilable version checked in for some GNU testing.
P.
Yury A. Bychkov wrote:
> After seeing some of the warnings that Linux compilation has produced me and
> Martin (during our phone meeting on Friday) have decided that while Martin
> reviews the API, I would change some of the code (mainly things that I did in
> the beginning of the porting process) from using instances to pointers. I've
> been putting off that task for a while, but it should fix some problems and
> improve the code a bit.
> Done so far: geom package.
> To do: Finish cleaning up the code. Bring the GEOS up to date with the latest
> JTS version (1.3), add namespace and continue the porting (with isValid).
> Yury
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
