[geos-devel] RE: [jts_discussion] Geotools.Net released (C# port of JTS 1.2)
Coats, Andy W AWCoats at URBANSCIENCE.com
Tue Jan 14 12:28:35 EST 2003
We found the OpenGIS simple features specification and liked it; I was
speaking to someone at SvgOpen about OpenGIS and how we would like to
implement Simple Features and they mentioned JTS.
We are 100% Microsoft shop so switching to Java (or J#) was not really
an option. But Java is so close to c# that the conversion was relatively
easy (if time consuming). During the conversion process I learned that
Java is more like C# than it is different. There was a couple of Java
language features that were used in 1.2 (anonymous classes) that have no
direct c# equivalent (I believe the next version of c# will have them.).
I was already a huge Open Source advocate, this project proved the point
with my manager. In some ways I almost wish I worked in Java because
there is so much more Open Source code in Java. I must say the Eclipse
IDE is also superb.
I'm excited by a C++ implementation. I'm dreaming that if it was exposed
via COM interfaces, spatial SQL could be implemented in SQL Server using
extended stored procedures. In the mean time, we are waiting for Yukon
(the next version of SQL Server); this will allow us C# to implement
spatial SQL.
In terms of managing the updates - the change from JTS 1.1 to 1.2 was
pretty quick (a couple of days). The test cases helped enormously. Our
QA guy packed them up as NUnit (similar to JUnit).
http://www.svgopen.com/
Java to C#
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Tuesday, January 14, 2003 12:12 PM
To: jts_discussion at yahoogroups.ca
Cc: GEOS Development List
Subject: Re: [jts_discussion] Geotools.Net released (C# port of JTS 1.2)
Andrew,
   This is quite amazing and unexpected! What led you to decide to do
this port?
   List in general. We now have two ports of JTS and soon will have
three when the GEOS port to C++ is complete. What are the implications
in terms of managing enhancements and updates to the algorithmic base of
JTS?
Paul
Andrew Coats wrote:
> Urban Science is proud to announce the beta release of its first
> Open Source Software Development project, Geotools.Net.
> Geotools.NET is hosted on SourceForge.net, the largest repository of
> Open Source code.  It is based on an Open Source Java implementation
> (JTS) of the OpenGIS Simple Features Specification.  Details and
> demos of Geotools.Net capabilities can be found on the home page.
> Home page
> http://geotoolsnet.sourceforge.net/Index.html
> SourceForge project page
> http://sourceforge.net/projects/geotoolsnet
> Andrew Coats
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
To unsubscribe from this group, send an email to:
jts_discussion-unsubscribe at yahoogroups.ca
Your use of Yahoo! Groups is subject to
http://ca.yahoo.com/docs/info/tos.html
