[geos-devel] Re: [postgis-users] GEOS / Predicates Update
Ferdinando Villa fvilla at zoo.uvm.edu
Thu May 22 14:24:12 EDT 2003
> >   - Re-write some chunks of GEOS to not throw exceptions. This is bad
> > for two reasons.  It is a large amount of work, and it also is bad
> > design.  The exceptions are there for a reason, and replacing them with
> > large chains of null handling will be unpleasant.  There are some
> > "exception emulation" libraries for C which could make the process less
> > unpleasant, but it will still not be nice at all.
> I'm voting for this option because I think the compiler-and-library
> version problem will solve itself over time (click your feet and say
> "there's no place like home").
> There are remarkably few THROWs in GEOS - only about 63.  There are
> only about 20 CATCHes.
...or maybe something like
template <typename return_value_of_func>
bool handle_error(GeosException* exc, return_value_of_func error_return)
	throw (GeosException*)
   if (geos::use_exceptions)
     throw exc;
   else
     delete exc;
   return error_return;
and instead of
   throw new GeosException(...);
we write
   return handle_geos_error(new GeosException(...),
                            whatever_we_should_return);
may be a bit of a pain to use the return value and it's ugly, but it
would control it all with a single global var and leave the exceptions
as a default option.
> The simpliest way to do the conversion would be to have the functions
> return, say, NULL if an error occurred.  The calling function would have
> to check to see if the result is NULL - if it is it could propogate the
> error up.
> For functions that have NULL as a valid result, you could return a
> simple object like this (excuse my java pseudo-code):
> 	boolean errorOccurred;
> 	Object result;
> The calling function would check to see if result.errorOccurred is true.
>    This could be auto-matically handled using macros.  There are already
> existing exceptions-for-C open source projects that do something like this.
> There are two problems with this:
> 1. I'm not sure how the code is layed out - there could be a large
> number of functions to check and modify.  It could also get ugly.
> 2. Libraries and things like templates may throw-errors-behind your back.
> >   - Re-write GEOS entirely, and again, in C. This at least would be a
> > clean implementation of the algorithms, but it is even more work, and
> > would constitute yet another port of JTS which would have to be kept
> > synchronous with the JTS R&D over time.
> I dont think this would be wise idea - its way too much work for too
> little gain.  Any C implementation would be uglier than C++ without
> exceptions.
> dave
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
ferdinando villa, ph.d.                    associate professor
gund institute for ecological economics, university of vermont
590 main street, burlington, vt 05405    phone: (802) 656-2972
