[geos-devel] Help with Compiling
strk strk at keybit.net
Mon Nov 24 18:29:27 EST 2003
gisrookie wrote:
> Hello
> I have downloaded and installed the Geos library on my computer and tried to
> compile one of the examples given in the same, but get a bunch of errors.  I
> think I need to compile the same by linking the libraries at the command
> line.  I would be thankful if anyone can help me with the above.
> Thanks in advance
> Sunil
Can you tell which examples did you try to compile and what are the first
lines of the errors you get ?
--strk;
