[geos-devel] is this a big leak?
Paul Ramsey pramsey at refractions.net
Fri Oct 3 00:20:55 EDT 2003
Great news! Time to run the conformance test suite again :)
On Thursday 02 October 2003 18:21, Yury A. Bychkov wrote:
> I've just fixed that leak in Overlay and committed the code to CVS.
> Yury
> ----- Original Message -----
> From: "Yury A. Bychkov" <me at yury.ca>
> To: "GEOS Development List" <geos-devel at geos.refractions.net>
> Sent: Wednesday, October 01, 2003 12:47 AM
> Subject: Re: [geos-devel] is this a big leak?
> > Yes, there is a leak in some of the overlay operations. It showed up in
> > one of the recent versions after a bugfix. I've been trying to plug it
> > for some time now, but it's rather weird so it'll probably take a couple
> > more days.
> > Yury
> > From: "David Blasby" <dblasby at refractions.net>
> > To: <geos-devel at geos.refractions.net>; "strk" <strk at keybit.net>
> > Sent: Tuesday, September 30, 2003 5:00 PM
> > Subject: [geos-devel] is this a big leak?
> > > Yuri,
> > > Find attached a program that creates a bunch of multipolygons and
> > > unions them together.
> > > It appears to leak memory quite quickly. Valgrind says:
> > > ==3035== 267096 bytes in 41 blocks are still reachable in loss record
> > > 14 of 14
> > > ==3035==    at 0x40168BBF: malloc (vg_clientfuncs.c:103)
> > > ==3035==    by 0x804AECA: __default_alloc_template<true,
> > > 0>::_S_chunk_alloc(unsigned int, int &)
> > > (/usr/include/g++-3/stl_alloc.h:490) ==3035==    by 0x804ACAB:
> > > 0>::_S_refill(unsigned int) (/usr/include/g++-3/stl_alloc.h:531)
> > > ==3035==    by 0x402D82FB: basic_string<char, string_char_traits<char>,
> > > __default_alloc_template<true, 0> >::replace(unsigned int, unsigned
> > > int, char const *, unsigned int) (/usr/include/g++-3/stl_alloc.h:332)
> > > ==3035==    by 0x402CE628: __static_initialization_and_destruction_0
> > > (/usr/include/g++-3/std/bastring.h:223)
> > > ==3035==    by 0x402CEAB1:
> > > geos::TopologyValidationError::TopologyValidationError(int,
> > > geos::Coordinate) (/usr/include/g++-3/stl_map.h:76)
> > > ==3035==    by 0x402D7424: (within /raid/local/lib/libgeos.so.1.0.0)
> > > ==3035==    by 0x4000CA20: _dl_init (dl-init.c:70)
> > > ==3035==    by 0x400012F0: (within /lib/ld-2.2.4.so)
> > > ==3035==
> > > ==3035== LEAK SUMMARY:
> > > ==3035==    definitely lost: 0 bytes in 0 blocks.
> > > ==3035==    possibly lost:   0 bytes in 0 blocks.
> > > ==3035==    still reachable: 267936 bytes in 54 blocks.
> > > ==3035==         suppressed: 0 bytes in 0 blocks.
> > > ==3035==
> > > I assume this is a leak of some sort - its a bit of a funny leak.
> > > dave
> > > // g++ -g test6.cpp -I/usr/local/include/geos -lgeos; ./a.out
> > > // g++ -g test6.cpp -I/usr/local/include/geos -lgeos ;
> > valgrind --leak-check=yes --num-callers=10 ./a.out
> > > #include "stdio.h"
> > > #include "io.h"
> > > #include "geom.h"
> > > using namespace geos;
> > > double global_offset = 0;
> > >     PrecisionModel *pm= new PrecisionModel();
> > > GeometryFactory *geomFactory = new GeometryFactory( pm, -1);
> > > //create a simple multi-polygon
> > > // offset shift the polygon to the left <offset> units
> > > // MULTIPOLYGON (((0.0000000000000000 0.0000000000000000,
> 10.0000000000000000
> > 0.0000000000000000, 10.0000000000000000 10.0000000000000000,
> 0.0000000000000000
> > 10.0000000000000000, 0.0000000000000000 0.0000000000000000),
> (2.0000000000000000
> > 2.0000000000000000, 4.0000000000000000 2.0000000000000000,
> > 4.0000000000000000 4.0000000000000000, 2.0000000000000000
> > 4.0000000000000000, 2.0000000000000000 2.0000000000000000)))
> > > Geometry *a(double offset)
> > > Geometry *g1, *g2 ;
> > >     Coordinate *c;
> > >     CoordinateList *cl;
> > >     LinearRing *outerRing;
> > >     vector<Geometry *> *innerRings=new vector<Geometry *>;
> > > LinearRing *innerRing;
> > >     vector<Geometry *> *polys=new vector<Geometry *>;
> > > cl = new BasicCoordinateList(5);
> > > c = new Coordinate(0+offset, 0);
> > > cl->setAt( *c ,0);
> > > delete c;
> > > c = new Coordinate(10+offset, 0);
> > > cl->setAt( *c ,1);
> > > delete c;
> > > c = new Coordinate(10+offset, 10);
> > > cl->setAt( *c ,2);
> > > delete c;
> > > c = new Coordinate(0+offset, 10);
> > > cl->setAt( *c ,3);
> > > delete c;
> > > cl->setAt( *c ,4);
> > > delete c;
> > > outerRing = (LinearRing*) geomFactory->createLinearRing(cl);
> > > c = new Coordinate(2+offset, 2);
> > > cl->setAt( *c ,0);
> > > delete c;
> > > c = new Coordinate(4+offset, 2);
> > > cl->setAt( *c ,1);
> > > delete c;
> > > c = new Coordinate(4+offset, 4);
> > > cl->setAt( *c ,2);
> > > delete c;
> > > c = new Coordinate(2+offset, 4);
> > > cl->setAt( *c ,3);
> > > delete c;
> > > cl->setAt( *c ,4);
> > > delete c;
> > > innerRing = (LinearRing *) geomFactory->createLinearRing(cl);
> > > innerRings->push_back(innerRing);
> > > g1 = geomFactory->createPolygon(outerRing, innerRings);
> > > polys->push_back(g1);
> > > g2 = geomFactory->createMultiPolygon(polys);
> > > return g2;
> > > //unions
> > > //    aa  AND
> > > //    a new geometry, which is the standard multipolygon translated to
> > > the
> > right
> > > Geometry *op(Geometry *aa)
> > > Geometry  *bb, *cc;
> > > bb = a(global_offset);
> > > //15 ==> leaks a lot
> > > //5  ==> leaks a constant amount
> > > global_offset += 15;
> > > cc = aa->Union(bb);
> > > delete aa;
> > > delete bb;
> > > return cc;
> > > int main(int argC, char* argV[])
> > > Geometry *aa;
> > > aa = a(global_offset);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > aa = op(aa);
> > > string s= aa->toString();
> > > cout << "geom1 == "<<s << endl;
> > > delete aa;
> > > delete geomFactory;
> > > delete pm;
> > > _______________________________________________
> > > geos-devel mailing list
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
