[geos-devel] Documentation
David Blasby dblasby at refractions.net
Tue Oct 7 17:32:50 EDT 2003
strk wrote:
> Who is responsible for GEOS overall architecture ?
This would be Martin Davis, Yuri Bychkov, and Paul Ramsey.  But, its
open source, so its really a community process.  If you have suggestions
- just post them to the list.
 >PS: I will try adding an example.cpp file containing what I've
 >understood so far ...
Excellent!
Personally, I'm not too concerned about returning copies of object or
the actual object (Although the latter has a big efficiency plus.).  We
just need to be consistent and explicit.
I think PostGIS is the only real application using GEOS at the moment -
and I'm willing to modify the POSTGIS->GEOS and GEOS->POSTGIS converters
if necessary.
I'm actually really quite impressed with GEOS in PostGIS. I've been
doing quite a bit of actual processing and checking using it!  Its so
much easier to write simple SQL instead of Java (or worse C++) code to
check data or actually process stuff.
Kudos to everyone involved!
dave
