[geos-devel] Documentation
Todd Vollmer tvollmer at digitalglobe.com
Tue Oct 7 18:46:31 EDT 2003
I would suggest that the correct way to write a function that must return a
object is to have that function return a new object not a pointer to the
object. Yes you will incur some overhead for creation of the object but you
will at least guarantee a  consistent behaviour.
Todd V.
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Tuesday, October 07, 2003 3:33 PM
To: GEOS Development List
Subject: Re: [geos-devel] Documentation
strk wrote:
> Who is responsible for GEOS overall architecture ?
This would be Martin Davis, Yuri Bychkov, and Paul Ramsey.  But, its
open source, so its really a community process.  If you have suggestions
- just post them to the list.
 >PS: I will try adding an example.cpp file containing what I've
 >understood so far ...
Excellent!
Personally, I'm not too concerned about returning copies of object or
the actual object (Although the latter has a big efficiency plus.).  We
just need to be consistent and explicit.
I think PostGIS is the only real application using GEOS at the moment -
and I'm willing to modify the POSTGIS->GEOS and GEOS->POSTGIS converters
if necessary.
I'm actually really quite impressed with GEOS in PostGIS. I've been
doing quite a bit of actual processing and checking using it!  Its so
much easier to write simple SQL instead of Java (or worse C++) code to
check data or actually process stuff.
Kudos to everyone involved!
dave
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20031007/f84f9e00/attachment.html
