[geos-devel] Was it a big memory leak ?
strk strk at keybit.net
Wed Oct 8 04:09:25 EDT 2003
It seems it was not, but a feature/bug of the STL library (caching).
valgrind FAQ contains tips on how to disable this binding in gcc
please read and comment on this - I think it should be specified
at configuration time wheter to force this or that behaviour
(when not possible at runtime).
--strk;
----- Forwarded message from Geoff Alexander <galexander2 at nc.rr.com> -----
To: "strk" <strk at keybit.net>, <valgrind-users at lists.sourceforge.net>
Cc: <dblasby at refractions.net>
Subject: Re: [Valgrind-users] still reachable from basic_string (C++)
Date: Tue, 7 Oct 2003 21:19:42 -0400
Looks like this may be Q14 in the valgrind FAQ
(http://developer.kde.org/~sewardj/docs-1.9.5/FAQ.txt).
Geoff Alexander
----- Original Message -----
To: <valgrind-users at lists.sourceforge.net>
Sent: Tuesday, October 07, 2003 5:29 PM
Subject: [Valgrind-users] still reachable from basic_string (C++)
> Does the following valgrind detect a memory leak in the libstdc++ ?
> ==2410== 114048 bytes in 26 blocks are still reachable in loss record 14
of 14
> ==2410==    at 0x4002A9A4: malloc (vg_replace_malloc.c:153)
> ==2410==    by 0x804BB6E: __default_alloc_template<true,
0>::_S_chunk_alloc(unsigned int, int &) (/usr/include/g++-3/stl_alloc.h:490)
> ==2410==    by 0x804B95B: __default_alloc_template<true,
0>::_S_refill(unsigned int) (/usr/include/g++-3/stl_alloc.h:531)
> ==2410==    by 0x402F092B: basic_string<char, string_char_traits<char>,
__default_alloc_template<true, 0> >::replace(unsigned int, unsigned int,
char const *, unsigned int) (/usr/include/g++-3/stl_alloc.h:332)
> ==2410==    by 0x402E78C7: __static_initialization_and_destruction_0
(/usr/include/g++-3/std/bastring.h:223)
> ==2410==    by 0x402E7D69:
geos::TopologyValidationError::TopologyValidationError(int,
geos::Coordinate) (/usr/include/g++-3/stl_map.h:76)
> ==2410==    by 0x402EFB04: (within /extra/geos/lib/libgeos.so.1.0.0)
> ==2410==    by 0x40286855: (within /extra/geos/lib/libgeos.so.1.0.0)
> ==2410==    by 0x4000D1D8: _dl_init (dl-init.c:70)
> ==2410==    by 0x40001DB0: (within /lib/ld-2.2.2.so)
> This sf.net email is sponsored by:ThinkGeek
> Welcome to geek heaven.
> http://thinkgeek.com/sf
> Valgrind-users mailing list
> Valgrind-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/valgrind-users
----- End forwarded message -----
