[geos-devel] intersect/intersection() problem under Win
strk strk at keybit.net
Thu Oct 16 13:12:21 EDT 2003
pschirus wrote:
> P.S.:
>  The TopologyException-Class is missing the toString()-Method.
> Can someone with write-Access to the CVS-Repository please copy this
> method from source/util/GEOSException.cpp to
> source/geom/TopologyException.cpp? Thank you.
I've made TopologyException derive from GEOSException,
you should get what you need now.
--strk;
