[geos-devel] Still Leaking in PostGIS
strk strk at keybit.net
Sun Oct 19 06:14:08 EDT 2003
pramsey wrote:
> I loaded up a polygon table, and then did this:
>    select wb_id from csn_waterbodies where isvalid(the_geom) limit 100;
> I did this over and over. Each time, the postgres instance I was
> connected to got a little bit larger. Probably this is repeatable with
> any data set at all, but I can provide the 100 records I used if necessary.
> P.
We should inspect stdlibc++ "smart" automatic memory caching/management.
I think if we can keep lib/compiler from using this "feature" (as an option
at compile/run time) it will be easier to debug these kind of leaks.
PS: is anybody mantaining the build system ?
--strk;
