[geos-devel] PostGIS Leak
strk strk at keybit.net
Tue Oct 21 02:56:46 EDT 2003
Can you try reproducing the bug I reported about WKTPrinting a point
geometry ? I can't understant if that is a problem with my environment.
--strk;
me wrote:
> I wonder if that leak could also be caused by the caching problem (from
> libstdc++ smart memory management). Unfortunately (as all of you probably know
> by now), my leak detector doesn't detect that. Can anyone with valgrind check if
> that is the case?
> Yury
> ----- Original Message -----
> From: "strk" <strk at keybit.net>
> To: "GEOS Development List" <geos-devel at geos.refractions.net>
> Sent: Monday, October 20, 2003 10:47 AM
> Subject: Re: [geos-devel] PostGIS Leak
> > pramsey wrote:
> > > About the PostGIS/GEOS leak I reported, I do not know if I quantified it
> > > in my email. Even though I was only running isvalid() with a limit of
> > > 100, I was adding over 1Mb of size to the postgres backend with each
> > > invocation. So, not a memory leak so much as a memory deluge. Could we
> > > have a bad PostGIS/GEOS interface now, after some of the GEOS changes?
> > > Paul
> > Yes. May be. I'll check tomorrow (tuesday).
> > --strk;
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
