[geos-devel] GEOSGetCoordinates() and performance (postgis bug fix)
strk strk at keybit.net
Fri Oct 24 17:27:47 EDT 2003
dblasby wrote:
> You mean in converting from GEOS->PostGIS geometries?  If you add
> a GEOS function (or to Postgis_geos_wrapper.cpp) that returns an integer
> instead of a string for geometrytype you'll be able to remove them.
I've added the following:
    enum geos::GeometryTypeId {
          GEOS_POINT,
          GEOS_LINESTRING,
          GEOS_POLYGON,
          GEOS_MULTIPOINT,
          GEOS_MULTILINESTRING,
          GEOS_MULTIPOLYGON,
          GEOS_GEOMETRYCOLLECTION
    GeometryTypeId Geometry::getGeometryTypeId() const;
PS: I've declared and defined the functions in geom.h for quick review.
--strk;
