AW: AW: [geos-devel] automake error??
Düster Horst Horst.Duester at bd.so.ch
Wed Sep 3 05:50:27 EDT 2003
Paul
I can't find a ./configure script in the snap shot 20030903
geos-cvs.tar.gz?????
Horst
-----Ursprüngliche Nachricht-----
Von: Paul Ramsey [mailto:pramsey at refractions.net]
Gesendet am: Dienstag, 2. September 2003 17:06
An: GEOS Development List
Betreff: Re: AW: [geos-devel] automake error??
If you are going to run autogen.sh, you should really replace the stock
automake, libtool, aclocal and autoconf with the latest versions. It
works much much nicer then. Just "rpm -e" the old ones and install the
new ones from source.
Failing that, the CVS daily snaphot now includes a ./configure script
which hopefully should be plug'n'play.
P.
Düster Horst wrote:
> Norman,
> I ask this question due to I'm not able to compile GEOS. You say automake
is
> OK. I think that configure runs OK but the compilation process breaks with
a
> lot of error messages I sent to the list some days ago. It was my last
hope
> that these messages were the cause of the compilation error.
> I believe that automake creates a wrong link path to the compiled objects.
> The error message says p.e.:
> gcc: ../algorithm/CentroidArea.lo: No such file or directory
> and occurs for all *.lo objects. All these objects were stored in the
> directory ../geom but not in the expected directories like
> ../algorithm
> ../graph
> etc.
> where the source is located.
> Perhaps you can help to find a solution.
> My system:
> redhat 7.2
> Horst
> Von: Norman Vine [mailto:nhv at cape.com]
> Gesendet am: Dienstag, 2. September 2003 16:37
> Betreff: RE: [geos-devel] automake error??
> Düster Horst writes:
>>Hallo all
>>When running autogen.sh automake-1.4-p5 reports the following messages:
>>automake: configure.in: installing `./install-sh'
>>automake: configure.in: installing `./mkinstalldirs'
>>automake: configure.in: installing `./missing'
>>configure.in: 160: installing `./config.guess
>>What's the meaning of these messages??
> automake is copying < or making symlinks > some files
> to the GEOS directory
> These files may be different depending on the automake
> version you are using
> This is normal behaviour
> see
> % info automake
> HTH
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
