[geos-devel] Compile Problem
Paul Ramsey pramsey at refractions.net
Mon Apr 5 15:50:03 EDT 2004
Oh, FYI, you can pull fedora RPMS from
http://postgis.refractions.net/rpms if you like...
P
Ken Lord wrote:
> Hello List,
> I am unable to compile GEOS, I am a bit of a novice and would
> appreciate any help.
> A short time into compiling the Hourly CVS Snapshot version of GEOS,
> I get the following error message:
> In file included from BasicCoordinateList.cpp:30:
> ../headers/geom.h:316: error: integer constant is too large for
> "long" type
> ../headers/geom.h:585: error: integer constant is too large for
> "long" type
> make[2]: *** [BasicCoordinateList.lo] Error 1
> make[2]: Leaving directory `/usr/src/geos-1.0/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/src/geos-1.0/source'
> make: *** [all-recursive] Error 1
> I have also tried the 2003/11/06 download, but it fails  when it
> finds I have automake 1.7.8 instead of 1.7.3.
> For this error I tried running aclocal as it states in the error
> message, but then i get the following error when i Make
> checking dynamic linker characteristics... GNU/Linux ld.so
> ./configure: line 18728: syntax error near unexpected token `long'
> ./configure: line 18728: `PGAC_TYPE_64BIT_INT(long int)'
> make: *** [config.status] Error 2
> I am running Fedora, with qt3.1, and gcc 3.3.2.
> Thanks,
> Ken Lord
> BGC Engineering Inc.
> Vancouver BC
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
