[geos-devel] Re: GEOS build scripts
Norman Vine nhv at cape.com
Wed Apr 14 17:36:06 EDT 2004
Paul Ramsey writes:
> Ah. Let's see if anyone on the list knows. It might just be that C++ takes a
> long time to compile (in general, this appears to be true, at least in GNU
> land).
> Quoting strk <strk at keybit.net>:
> > The build system works, this is sure.
> > What I'm not sure about is the correctness of filed dependencies.
> > I do not know wheter automake does take care of deps or if it is
> > programmer responsibility to set them somehow.
> > My problem is that the build time is very very long, and I'm
> > trying to understand if this is due to 'conservative'
> > dependencies, autotool paranoia, or C++ compile itself.
Libtool will take care of the dependencies
You might want to investigate ccache to speed up compilation
http://ccache.samba.org/
HTH
Norman
