[geos-devel] Patch for 1.0.0 for my single issue
strk strk at keybit.net
Mon Apr 26 05:35:35 EDT 2004
On Sun, Apr 25, 2004 at 11:58:19PM -0400, Carl Anderson wrote:
> strk,
> I tracked down the cause of my problem in geos-1.0.0 and backported the
> fix from JTS-1.4
> I have made no other changes and the patched lib does not Assert or
> Exception for my test set. (of about 1 million objects).
> I feel that this is worthwhile as a short term fix to geos-1.0 while
> the bigger set of changes in CVS are stabilized.
I think Paul takes care of this, he is the package master :)
Maybe distributing your patch would be enough...
> WRT geos-cvs should I wait or can I start searching for the cause of
> the Asserts / Exceptions now?
I'd start searching...
--strk;
> C.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
