[geos-devel] depth mismatch
strk strk at keybit.net
Mon Apr 26 11:58:38 EDT 2004
Know what, the depth mismatch exception is now thrown when
trying bufferOriginalPrecision() ...
Since its caller expect any TopologyException to be the
sign it needs to reduce the argument geometry precision,
it does and it gets to a result at the first bufferFixedPrecision
call, but it's being harder to understand what the problem is.
In particular, is the 'depth mismatch' really the kind of exception
expected by BufferOp::computeGeometry(), or should it be threated
differently ??
--strk;
On Wed, Apr 21, 2004 at 04:18:53PM +0200, strk wrote:
> Fiuuuuu!. Found.
> Was an error in DirectedEdgeStar::computeDepths.
> It seems to work now.
> --strk;
> On Wed, Apr 21, 2004 at 04:10:32PM +0200, strk wrote:
> > Hello Martin,
> > I'm trying to figure out why doesn't the buffer operation
> > work in GEOS CVS. Turning some debugging on I receive
> > 	TopologyException: depth mismatch (150,350)
> > at every  bufferFixedPrecision() attempt but the one with 0 precision
> > digits (the last one) which in turn drops an empty resultGeometry.
> > Can you tell me if sizeBasedScaleFactor matches max precision digits ?
> > And more on, what is a depth mismatch exception ?
> > TIA
> > --strk;
> > Here is the complete debugging output:
> > POINT (150.00 350.00)
> > Trying with 12 max precision digits
> > sizeBasedScaleFactor: 1e+10
> > TopologyException: depth mismatch at  (150,350)
> > Trying with 11 max precision digits
> > sizeBasedScaleFactor: 1e+09
> > Trying with 10 max precision digits
> > sizeBasedScaleFactor: 1e+08
> > Trying with 9 max precision digits
> > sizeBasedScaleFactor: 1e+07
> > Trying with 8 max precision digits
> > sizeBasedScaleFactor: 1e+06
> > Trying with 7 max precision digits
> > sizeBasedScaleFactor: 100000
> > Trying with 6 max precision digits
> > Trying with 5 max precision digits
> > Trying with 4 max precision digits
> > Trying with 3 max precision digits
> > Trying with 2 max precision digits
> > Trying with 1 max precision digits
> > sizeBasedScaleFactor: 0.1
> > Trying with 0 max precision digits
> > sizeBasedScaleFactor: 0.01
> > resultGeom != NULL
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
