[geos-devel] Re: [Mapserver-users] GEOS: buffer function for MULTIPOLYGON geometry object
Paul Ramsey pramsey at refractions.net
Thu Apr 29 17:52:01 EDT 2004
What is isvalid() return for your geometry? True or false? A
multipolygon as you describe sounds suspiciously like an invalid shape.
songzh at cs.orst.edu wrote:
> Hello list:
>   I recently tested GEOS 'buffer(MULTIPOLYGON_geo_column, 100)' function and
> found something strange:
>   1) I manually created a MULTIPOLYGON object which is shown as two trangles
> connected by one point.
>   2) then I issued command as:
> "update motelsites set buffer_py=buffer(the_geom_py,500) where gid=36;"
>   3) The strange thing is: only the left triangle has been buffered and the
> buffer area has been shown around this triangle. The right triangle didn't show
> up its buffered area at all.
>   Did I do anything wrong or there is some problem with the GEOS's buffer
> function to deal with MULTIPOLYGON object ?
>   Thanks for any advice!
> Zhigang Song
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
