[geos-devel] swig module committed to CVS
Paul Ramsey pramsey at refractions.net
Thu Aug 19 23:53:56 EDT 2004
Sean,
Sorry, I just noticed that the 2.0.0 release is missing the swig stuff.
This is because I am using the 'make dist' functionality of our build
environment to make the distribution archive. I am going to try and keep
doing that, so that cutting a release is dead easy. To get the swig
stuff into the next release, we will have to add the appropriate
Makefile.am entries to the relevant places... as you can see, I am hand
waving. :) I am still feeling my way with the fancy auto* build tools.
Paul
Sean Gillies wrote:
> I've committed the start of a swig interface for GEOS
> scripting modules.  All the classes in geom.h, io.h, and
> util.h are wrapped, providing Geometry classes, WKTReader
> and WKTWriter, and the GEOSExceptions.
> Code examples for using it can be found in the unit tests
> under swig/python/tests/cases.
