[geos-devel] Makefile changes
Norman Vine nhv at cape.com
Sat Dec 4 16:53:32 EST 2004
Hi all
Could someone please fold the atached diffs into the CVS
==== change log ======
configure.in:
    removed deprecated AC_LIBTOOL_WIN32_DLL directive
doc/Makefile.am:
source/bigtest/Makefile.am:
source/examples/Makefile.am
source/test/Makefile.am
     use automake variables for LIBS and INCLUDES make variables
< following for list archives >
Note for building with Cygwin or MingW you might need to add a
couple of includes to the libtool script
search for "cvswrappersource" in the libtool file to find the appropriate
location
Cheers
Norman
*** libtool.bak Sat Dec  4 16:04:18 2004
--- libtool     Sat Dec  4 16:08:10 2004
*** 6417,6456 ****
--- 6417,6458 ----
            cat > $cwrappersource <<EOF
  /* $cwrappersource - temporary wrapper executable for $objdir/$outputname
     Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
     The $output program cannot be directly executed until all the libtool
     libraries that it depends on are installed.
     This wrapper executable should never be moved out of the build directory.
     If it is, it will not operate correctly.
     Currently, it simply execs the wrapper *script* "/bin/sh $output",
     but could eventually absorb all of the scripts functionality and
     exec $objdir/$outputname directly.
  EOF
            cat >> $cwrappersource<<"EOF"
  #include <stdio.h>
  #include <stdlib.h>
  #include <unistd.h>
+ #include <string.h>
+ #include <ctype.h>
  #include <malloc.h>
  #include <stdarg.h>
  #include <assert.h>
  #include <sys/stat.h>
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20041204/d47b3b35/diffs.obj
