[geos-devel] Library Creation
Paul Ramsey pramsey at refractions.net
Fri Feb 20 00:47:24 EST 2004
Problem found and "solved".
The version of ltmain in the CVS archive did not match the libtool on
the build box.
Now that they match, 'make dist' creates a much nicer result, one that
creates .so files.
P.
On Thursday, February 19, 2004, at 05:28 PM, Paul Ramsey wrote:
> A couple people (and now me) have experienced geos being installed
> *without* the .so suffix after a 'make install' command.  Strk, could
> you check this out?
> P.
>      Paul Ramsey
>      Refractions Research
>      Email: pramsey at refractions.net
>      Phone: (250) 885-0632
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
      Paul Ramsey
