[geos-devel] documentation 1.0.0
strk strk at keybit.net
Tue Jul 20 12:55:31 EDT 2004
On Tue, Jul 20, 2004 at 12:24:32PM -0400, Maude Giasson wrote:
> I am using the geos-1.0.0 revision.
> I didn't find any API documentation for that revision; is it possible to dowload any "already-generated" documentation ? If yes, where can I find it ?
> Thanks
> Maude Giasson
If you have the source code you will find a file doc/example.cpp
containing basic example usage of GEOS. Geometry construction
and operations.
Be aware that next GEOS release (coming out soon)
will have a modified API (and also a shipped documentation).
