[geos-devel] Re: [postgis-users] Win32 PostgreSQL 7.5/PostGIS snapshot update
Paul Ramsey pramsey at refractions.net
Mon Jun 7 13:09:42 EDT 2004
Hey Mark,
Do you have a test case for the memory leak in GEOS-CVS? We are trying
to stomp those all down so we can do a numbered release in the nearish term.
Thanks,
Paul
Mark Cave-Ayland wrote:
> Hi guys,
> Just to let you know I've updated my Win32 snapshot again at
> http://www.webbased.co.uk/mca/pgsql75win.zip. The CVS snapshot of GEOS
> that I used in the original build was found to have some bugs in it
> which could cause out of memory errors and/or the backend to die when
> using certain GEOS functions. This version of the snapshot is compiled
> against the proper GEOS 1.0 release and now things appear to work as
> they should. If you are not using any GEOS function then this will not
> affect you! Note I have not upgraded the PostgreSQL snapshot so you can
> copy your existing data/ directory into the new distribution and
> continue working as before.
> Many thanks to David Techer for his help and patience solving this
> problem.
> Mark.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
