[geos-devel] Interface consistency
strk strk at keybit.net
Tue Jun 15 11:04:34 EDT 2004
On Tue, Jun 15, 2004 at 04:26:32PM +0200, strk wrote:
> On Tue, Jun 15, 2004 at 10:15:31AM -0400, Frank Warmerdam wrote:
> > strk wrote:
> > >Before releasing next GEOS I'd like to fix interface inconsistencies.
> > >Namely some geometry constructors take ownership over passed
> > >components:
> > >	o Polygon::Polygon(LinearRing *shell, vector<Geoemtry *> *holes)
> > >		will not copy shell and holes, and destroy it at
> > >		polygon destruction time.
> > >	o GeometryCollection::GeometryCollection(const vector<Geometry
> > >	*>*geoms)
> > >		will copy vector, but not geoms, which it will destroy
> > >		at GeometryCollection destruction time.
> > >	o MultiGEOM::MultiGEOM(const vector<GEOM *>*geoms)
> > >		see GeoemtryCollection constructor
> > >Other geometry constructors all copy their arguments. I think this needs
> > >to be fixed to "all-constructors-copy-arguments". This will break existing
> > >applications, but if we make the change now I don't think there will be
> > >so much applications involved.
> > Strk,
> > I ran up against a similar issue in GDAL and ended up having two forms of
> > some of the "attach" methods.  For instance, I have an addRing() method on
> > the OGRPolygon as well as an addRingDirectly().  The "directly" method takes
> > ownership of the passed geometry and can save alot of clone/delete overhead
> > in many common situations.
> > I gather that the only way to attach the subgeometries to a GEOS geometry
> > is during the constructor, is that right?  That is, the geometries are
> > essentially immutable after creation?   This makes it harder to have
> > explicit
> > means to create attach the geometry with different rules via different named
> > methods.
> There is an apply_rw method by which geometry modification is possible.
> > I would suggest adding a "bool takeOwnership" argument to the constructors
> > which is defaulted to false. This allows code that wants to avoid the
> > clone/delete overhead to explicitly control ownership but returns the
> > default
> > to a consistent approach.
> This is what I was thinking about, unfortunately this would not be
> transparent...
I wanted to add that this would break 'const correctness' of the code,
as it would be impossible to know at compile time whether the given
argument will need threatment as a 'const' or a 'non const'.
--strk;
> > I would add that behavioural changes like this are an awful source of bugs.
> > All code written against GEOS so far will need careful review to see if this
> > behavioural change affects them.  The sooner a change such as this is made,
> > the better.
> I know... anyway I'm sure this *really* needs to be done.
> > PS. My integration of GEOS into OGR is going very well.
> Good to know :)
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
