[geos-devel] Interface changes
strk strk at keybit.net
Wed Jun 16 09:18:46 EDT 2004
I've updated GEOS interface to make all geometry constructors
copy given arguments (vector AND content).
As a side effect:
        o SegmentString constructor also copy given CoordinateList
          and deletes it at destruction time
        o SegmentString::getCoordinates() returns a copy of internal
          CoordinateList
        o new SegmentString::getCoordinatesRO() returns a pointer to
          the internal CoordinateList (no copy involved)
        o GeometryFactory::buildGeometry always returns a newly
          allocated geometry, so that the caller is free to delete
          arguments passed to it.
        o GeometryFactory geometry collection creators
          (createMulti*, createGeometryCollection) copy given
          vector AND content.
Reasoning about clients switched I've found that geos-config was
broken in GEOS-1.0 (run with --version returned @@GEOS_VERSION@@
instead of actual version). I've fixed that, but I think a version
number (major,minor,patchlevel) should be put in some header for
ease of use. What do you think Frank ?
--strk;
