[geos-devel] Interface changes
strk strk at keybit.net
Wed Jun 16 11:00:10 EDT 2004
On Wed, Jun 16, 2004 at 10:31:53AM -0400, Ferdinando Villa wrote:
> On Wed, 2004-06-16 at 10:28, Ferdinando Villa wrote:
> > Yes, or better, have these defined in geos_version.h and include it
> > first thing in geom.h (btw - shouldn't it be geos.h, or maybe we should
> > have a geos.h including geos_version.h and geom.h?). I usually prefer to
> > have version numbers configured in configure.in and use the gcc command
> > line to propagate them, but this has the disadvantage of needing a
> > different strategy for Windows. Your defs and interface functions sound
> > great to me.
> ...on second thought, having it #defined in a header file will prevent
> automake checking through a macro, as done in geos.m4, and require
> tedious programming using geos-config (the configuration script won't
> know the version, and I would strongly argue against duplicating the
> info). So maybe there are arguments to keep the four defines as
> variables in configure.in, although I don't know what's required to do
> the same in Win.
The main GEOS application is Postgis.
Postgis does not have an autoconf interface, so geos.m4
won't be useful for it. It will *need* #defines to work
correctly.
As for geos.h / geom.h there is currently no single header
defining all the operations available with geos.
Postgis - for example - includes geom.h and util.h (another
*really* dangerous name).
Maybe GEOS should provide a 'public' geos.h containing all public
and protected interfaces as well as version infos. This could
hopefully be done automatically.
Finally, for the geos.m4 macro. I see no problem in writing
version info in configure.in. The geos_version.h (or geos.h)
would be substitution targets the same as geos-config.
--strk;
> > ferdinando
> > > I think these would be useful to have:
> > > 	#define GEOS_MAJOR_VERSION 1
> > > 	#define GEOS_MINOR_VERSION 4
> > > 	#define GEOS_PATCHLEVEL 0
> > > 	#define GEOS_VERSION "1.4.0"
> > > 	int geos::geos_major_version();
> > > 	int geos::geos_minor_version();
> > > 	int geos::geos_patchlevel();
> > > 	string geos::geos_version();
> > > Comments ?
> > > BTW, to split version in major/minor/patchlevel configure.in should also
> > > be modified..
> > > > One point about version numbers: the geos.m4 macro file that I added to
> > > > the distribution (which defines GEOS_INIT(version) to be used in
> > > > configure.in by any automake-based program that wants to check for geos)
> > > > depends on having all three version numbers, and will not work correctly
> > > > with two. So if we want that to keep working, we should have 1.4.0, not
> > > > 1.4, or the m4 macro should be made smarter (probably a better idea).
> > > probably a better idea...
> > > --strk;
> > > > Ciao,
> > > > ferdinando
> > > > On Wed, 2004-06-16 at 09:18, strk wrote:
> > > > > I've updated GEOS interface to make all geometry constructors
> > > > > copy given arguments (vector AND content).
> > > > > As a side effect:
> > > > >         o SegmentString constructor also copy given CoordinateList
> > > > >           and deletes it at destruction time
> > > > >         o SegmentString::getCoordinates() returns a copy of internal
> > > > >           CoordinateList
> > > > >         o new SegmentString::getCoordinatesRO() returns a pointer to
> > > > >           the internal CoordinateList (no copy involved)
> > > > >         o GeometryFactory::buildGeometry always returns a newly
> > > > >           allocated geometry, so that the caller is free to delete
> > > > >           arguments passed to it.
> > > > >         o GeometryFactory geometry collection creators
> > > > >           (createMulti*, createGeometryCollection) copy given
> > > > >           vector AND content.
> > > > > Reasoning about clients switched I've found that geos-config was
> > > > > broken in GEOS-1.0 (run with --version returned @@GEOS_VERSION@@
> > > > > instead of actual version). I've fixed that, but I think a version
> > > > > number (major,minor,patchlevel) should be put in some header for
> > > > > ease of use. What do you think Frank ?
> > > > > --strk;
