[geos-devel] Examples using GEOS from C?
David Blasby dblasby at refractions.net
Wed Jun 16 12:23:26 EDT 2004
Steve Lime wrote:
> Hi Folks: I'm starting to tinker with using GEOS with MapServer. I'm
> wondering if folks have any examples of using it from within straight C
> code. I'd also be interested in learning more about the best ways to
> operate on non-GEOS geometries. I've heard folks mention that there
> should be more efficient ways than converting between representations.
> Thanks!
PostGIS is a C program, so if you look in there you'll see an example.
Basically, I wrote a very very simple C++ library
(postgis_geos_wrapper.cpp) that interfaced with GEOS.   If you tag your
C++ functions with 'extern "C"', you'll be able to call them from a C
library (postgis_geos.c).
You'll have to write your own constructors that take the mapserv
ShapeObjs and convert to GEOS geometries.  You can either construct
brand-new real-live GEOS Coordinates, or you can wrap the ShapeObj
coordinates with a CoordinateList class.
For example:
(C++:)
extern "C" char GEOSisSimple(Geometry *g1);
	try
		return g1->isSimple();
	catch (GEOSException *ge)
			// give error message as a NOTICE
		NOTICE_MESSAGE((char *)ge->toString().c_str());
		delete ge;
		return 2;  // error occured
	catch (...)
		return 2; //error occured
(C:)
Datum issimple(PG_FUNCTION_ARGS)
	GEOMETRY		*geom = (GEOMETRY *)  PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
	Geometry *g1;
	int result;
	if (geom->nobjs == 0)
		PG_RETURN_BOOL(true);
		initGEOS(MAXIMUM_ALIGNOF);
	//elog(NOTICE,"GEOS init()");
		g1 = 	POSTGIS2GEOS(geom ); // construct GEOS geometry
		result = GEOSisSimple(g1);
		GEOSdeleteGeometry(g1);
			if (result == 2)
				elog(ERROR,"GEOS issimple() threw an error!");
				PG_RETURN_NULL(); //never get here
	PG_RETURN_BOOL(result);
