[geos-devel] geos-config
Stephen Lime sdlime at comcast.net
Fri Jun 25 00:38:23 EDT 2004
Hi folks: Trying to integrate geos into a configure script based on the
output from geos-config. I'm curious if the --includes and --cflags
options should be producing the same output (they do). I expected one
of them to produce "-I/usr/local/include/geos". I can work around this
using the --prefix but was wondering if the behavior is as intended.
Steve
