[geos-devel] geos-config
strk strk at keybit.net
Fri Jun 25 11:38:06 EDT 2004
On Fri, Jun 25, 2004 at 10:48:57AM -0400, Ferdinando Villa wrote:
> Ugh... ok that's not too bad, but would it be terribly messy to put all
> headers under a geos/ directory and include all of them with the same
> notation everywhere? The build process for postgis etc wouldn't change
> as long as geos-config is used... the BUILDING_GEOS conditional sounds a
> bit perverse to me... and I think we really need to prefix header files
> to avoid ambiguities. If folks think we should do it this way, I can
> volunteer to code that in if it's too much work for one person.
postgis build process should change because geos wrapper includes
geom.h and util.h (with no geso/ prefix) but I can take care of this
(maybe including just geos.h for GEOS_VERSION > 1.0.0)
Your contribution is welcome in moving all the stuff as I think it
might be a bigger work then it looks. Let's see what does Paul
think about this.
--strk;
> On Fri, 2004-06-25 at 10:47, strk wrote:
> > On Fri, Jun 25, 2004 at 10:31:18AM -0400, Ferdinando Villa wrote:
> > > That's debatable, but my vote would go to cflags pointing to /includes,
> > > and prefixing all includes as geos/. I don't see
> > > a problem in having geo{s|m}.h containing lines like
> > > #ifndef __geos_platform_h
> > > #include <geos/platform.h>
> > > #endif
> > > using the bracket notation should keep us safe from ambiguity and it
> > > would work as long as the include path is given as /includes. Looks
> > > elegant to me, too, but that's me...
> > Note that geom.h is included by GEOS modules themself, whose headers
> > do not currently reside under a geos/ directory, so the switch should
> > be something like
> > #ifdef __BUILDING_GEOS
> > #include "platform.h"
> > #else
> > #endif
> > The switch would not be needed for geos.h since it is a front-end only
> > header file....
> > --strk;
> > > cheers
> > > f
> > > On Fri, 2004-06-25 at 10:29, strk wrote:
> > > > On Fri, Jun 25, 2004 at 09:16:08AM -0400, Ferdinando Villa wrote:
> > > > > Yes - --cflags should produce the -I line, --includes should just list
> > > > > the path. The current script is buggy - strk can you fix it?
> > > > The fix is in current CVS.
> > > > Ferdinando, do you think includes should be
> > > > .../includes or .../includes/geos ?
> > > > I'd like application to use #include "geos/geom.h" or
> > > > similar (which would work with current geos-config output)
> > > > but then geom.h includes platform.h (and not geos/platform.h)
> > > > and it should not work then....
> > > > What do you think should be done about this ?
> > > > --strk;
> > > > > The procedure to use the geos.m4 macro is as follows:
> > > > > put GEOS_INIT(1.0.0) in configure.int
> > > > > run aclocal -I macros instead of aclocal
> > > > > the rest is the same
> > > > > your CXXFLAGS will include the geos path automatically and your LIBS
> > > > > will link geos in.
> > > > > ferdinando
> > > > > On Fri, 2004-06-25 at 04:40, strk wrote:
> > > > > > I don't like this also.
> > > > > > I think it should produce just the path without the -I switch.
> > > > > > Anyway, you should find a geos.m4 file in the GEOS distribution
> > > > > > handy for application's configure scripts.
> > > > > > --strk;
> > > > > > On Thu, Jun 24, 2004 at 11:38:23PM -0500, Stephen Lime wrote:
> > > > > > > Hi folks: Trying to integrate geos into a configure script based on the
> > > > > > > output from geos-config. I'm curious if the --includes and --cflags
> > > > > > > options should be producing the same output (they do). I expected one
> > > > > > > of them to produce "-I/usr/local/include/geos". I can work around this
> > > > > > > using the --prefix but was wondering if the behavior is as intended.
> > > > > > > Steve
> > > > > > > _______________________________________________
> > > > > > > geos-devel mailing list
> > > > > > > geos-devel at geos.refractions.net
> > > > > > > http://geos.refractions.net/mailman/listinfo/geos-devel
