[geos-devel] Version Check
strk strk at keybit.net
Sun Jun 27 20:21:40 EDT 2004
On Sun, Jun 27, 2004 at 09:26:08AM -0700, Paul Ramsey wrote:
> It seems suspiciously like acsite.m4 is being ignored, that is for
> sure, since that macro is not getting expanded in configure. Arg, as
> they say in the movies.
Fernando, do you have any suggestion on how to handle this
situation ?
--strk;
> On Sunday, June 27, 2004, at 03:11 AM, strk wrote:
> >On Sat, Jun 26, 2004 at 06:40:55PM -0700, Paul Ramsey wrote:
> >>OK, I need a version check. I am getting no love trying to compile the
> >>CVS tip on OS/X.
> >>./configure: line 7359: syntax error near unexpected token
> >>`PGAC_TYPE_64BIT_INT(long'
> >>./configure: line 7359: `PGAC_TYPE_64BIT_INT(long int)'
> >>automake (GNU automake) 1.6.1
> >>autoconf (GNU Autoconf) 2.52
> >>gcc 2.95.2
> >>When did we get this 64bit test in configure.in, btw?
> >It's been there since release 1.0, needed to make 64 integers usable
> >in a portable way. The macro is defined in acsite.m4 and have been
> >copied from postgresql 7.3.4. It helps defining int64 to 'long' or
> >'long long' (unavailable on some systems).
> >You error message suggests to me the acsite.m4 file has not been
> >parsed by autoconf when producing 'configure' (there should be no
> >PGAC_TYPE.. call in the 'configure' script itself).
> >I'm using GNU Autoconf 2.57 with success. Note that autoconf reads
> >both aclocal.m4 and acsite.m4. I did not use aclocal.m4 because that
> >is currently generated by 'aclocal'. Maybe Fernando can help
> >with these auto* tools.
> >--strk;
> >>     Paul Ramsey
> >>     Refractions Research
> >>     Email: pramsey at refractions.net
> >>     Phone: (250) 885-0632
> >>_______________________________________________
> >>geos-devel mailing list
> >>geos-devel at geos.refractions.net
> >>http://geos.refractions.net/mailman/listinfo/geos-devel
>      Paul Ramsey
