[geos-devel] Problems creating polygons with holes
Darren Carman darren.carman at infoterra-global.com
Mon Jun 28 06:05:22 EDT 2004
defs:
typedef struct boundaryPt {
  double x;
  double y;
typedef vector<boundaryPt>    boundary;
typedef vector<boundary>      boundaryList;
typedef vector<boundaryList>  polygonList;
class members used:
  polygonList       ptPolygons;
  string tmpStr;
  string errMsg;
class function:
string c_polygon_gml::WKTString(void) {
  TRACE_FUNC("c_polygon_gml::WKTString");
  vector<Geometry *> polygons;
  vector<Geometry *> holes;
  int i,j,k;
  string resStr = "";
  try{
    GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
    // for each outer ring create a CoordinateList and add all the points to it
    for(i=0; i< static_cast<int>(ptPolygons.size()); i++) {
      CoordinateList *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
      boundaryList bl = ptPolygons[i];
      boundary b = bl[0];
      TRACE_OUTPUT("Polygon " << i);
      for(k=0; k< static_cast<int>(b.size()); k++) {
        TRACE_OUTPUT("Added point " << b[k].x << ',' << b[k].y);
        cl1->add(*(new Coordinate(b[k].x,b[k].y)));
      // for each hole create a coordinate list like above, create a polygon and add to a Geometry vector
      for(j=1; j< static_cast<int>(bl.size()); j++) {
        TRACE_OUTPUT("Hole " << j);
        boundary b = bl[j];
        CoordinateList *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
          cl2->add(*(new Coordinate(b[k].x,b[k].y)));
        TRACE_OUTPUT("Creating polygon for hole " << j << ": " << cl2->toString());
        Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl2),NULL);
        TRACE_OUTPUT("Geometry " << j << " : " << geom1->toString());
        holes.push_back(geom1);
        delete cl2;
      // create a polygon from the 1st CoordinateList and the holes
      TRACE_OUTPUT("Creating polygon " << i << ": " << cl1->toString());
      Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl1),&holes);
      TRACE_OUTPUT("test ");
      TRACE_OUTPUT("Geometry " << i << " : " << geom2->toString());
      // save this polygon in another vector
      TRACE_OUTPUT("Adding polygon " << i);
      polygons.push_back(geom2);
      delete cl1;
    TRACE_OUTPUT("Creating multi-polygon");
    // when all done create a MultiPolygon object
    Geometry *geom3=gf->createMultiPolygon(&polygons);
    TRACE_OUTPUT("Creating string");
    resStr = geom3->toString();
    //clean up
    delete geom3;
    delete gf;
  catch (GEOSException *ge) {
    errMsg = ge->toString();
  return resStr;
XML read in by class and stored in ptPolygons:
<AreaDefinition>
<GDSRequest>
<query>
<AreaQuery outputContent="public">
<queryArea>
<Polygon srsName="osgb:BNG">
<outerBoundaryIs>
<LinearRing>
<coordinates>
339252,1019302
339252,1029077
348752,1029077
346102,1019653
339252,1019302
</coordinates>
</LinearRing>
</outerBoundaryIs>
<innerBoundaryIs>
<LinearRing>
<coordinates>
340000,1020000
340000,1021000
341000,1021000
341000,1020000
340000,1020000
</coordinates>
</LinearRing>
</innerBoundaryIs>
</Polygon>
</queryArea>
</AreaQuery>
</query>
</GDSRequest>
</AreaDefinition>
Output:
TR: TRACE ENTRY:c_polygon_gml::WKTString line 168 file c_polygon_gml.cpp
TR:   Polygon 0
TR:   Added point 339252,1.0193e+06
TR:   Added point 339252,1.02908e+06
TR:   Added point 348752,1.02908e+06
TR:   Added point 346102,1.01965e+06
TR:   Hole 1
TR:   Added point 340000,1.02e+06
TR:   Added point 340000,1.021e+06
TR:   Added point 341000,1.021e+06
TR:   Added point 341000,1.02e+06
TR:   Creating polygon for hole 1: (340000,1.02e+06,1.7e-308) (340000,1.021e+06,1.7e-308) (341000,1.021e+06,1.7e-308) (341000,1.02e+06,1.7e-308) (340000,1.02e+06,1.7e-308)
TR:   Geometry 1 : POLYGON ((340000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1020000.0000000000000000))
TR:   Creating polygon 0: (339252,1.0193e+06,1.7e-308) (339252,1.02908e+06,1.7e-308) (348752,1.02908e+06,1.7e-308) (346102,1.01965e+06,1.7e-308) (339252,1.0193e+06,1.7e-308)
TR:   test
Segmentation fault
Output when the hole is removed:
TR:   Polygon 0
TR:   test
TR:   Geometry 0 : POLYGON ((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000))
TR:   Adding polygon 0
TR:   Creating multi-polygon
TR:   Creating string
TR: TRACE EXIT:c_polygon_gml::WKTString
ERROR:
WTF format
MULTIPOLYGON (((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000)))
-----Original Message-----
Sent: 28 June 2004 11:01
To: GEOS Development List
Subject: Re: [geos-devel] Problems creating polygons with holes
Can you send the test code ?
There are currently no known bug ...
--strk;
On Mon, Jun 28, 2004 at 10:15:45AM +0100, Darren Carman wrote:
> Hi all,
> I am creating polygons with holes and want to use geos to allow me to output them in WKT.
> A polygon without a hole works fine, but as soon as I add a hole I get a segmentation fault after calling the createPolygon function (GeometryFactory) and trying to run toString on that polygon.
> I am using version 1.0.
> I have tried getting the latest version from CVS but this causes a segmentation fault to occur while adding the 5th polygon coordinate to the CoordinateList (there are only 4 coordinates in the test polygon, the 5th being the first one repeated - I tried making it 6 to see if it was a problem with closing the polygon but I still got a segmentation fault while adding the 5th).
> Is there a fix for this, or has anyone come accross it?
> Thanks in advance,
> Darren
> "The information in this e-mail and any attachment is confidential and may be privileged. If you have received this e-mail in error, please delete it immediately and destroy any copies on your system. You should not retain, copy or use this e-mail for any purpose, nor disclose all or any part of its content to any other person.
> Opinions expressed in this e-mail may not be endorsed by the company and unless explicitly indicated, this e-mail shall not form part of any binding agreement".
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
