[geos-devel] Problems creating polygons with holes
Darren Carman darren.carman at infoterra-global.com
Mon Jun 28 06:47:17 EDT 2004
#include <geos/io.h>
#include <geos/geom.h>
using namespace std;
using namespace geos;
typedef struct boundaryPt {
  double x;
  double y;
typedef vector<boundaryPt>    boundary;
typedef vector<boundary>      boundaryList;
typedef vector<boundaryList>  polygonList;
polygonList       ptPolygons;
int main(int argc, char *argv[]) {
  vector<Geometry *> polygons;
  vector<Geometry *> holes;
  int i,j,k;
  string resStr = "";
  boundaryPt poly1[5];
  boundaryPt hole1[5];
  boundary tmpBoundary;
  boundaryList tmpBoundaryList;
  poly1[0].x = 339252;
  poly1[0].y = 1019302;
  poly1[1].x = 339252;
  poly1[1].y = 1029077;
  poly1[2].x = 348752;
  poly1[2].y = 1029077;
  poly1[3].x = 346102;
  poly1[3].y = 1019653;
  poly1[4].x = 339252;
  poly1[4].y = 1019302;
  hole1[0].x = 340000;
  hole1[0].y = 1020000;
  hole1[1].x = 340000;
  hole1[1].y = 1021000;
  hole1[2].x = 341000;
  hole1[2].y = 1021000;
  hole1[3].x = 341000;
  hole1[3].y = 1020000;
  hole1[4].x = 340000;
  hole1[4].y = 1020000;
  for (i=0; i<5; i++) {
    tmpBoundary.push_back(poly1[i]);
  tmpBoundaryList.push_back(tmpBoundary);
  tmpBoundary.clear();
    tmpBoundary.push_back(hole1[i]);
  ptPolygons.push_back(tmpBoundaryList);
  for(int i=0; i< static_cast<int>(tmpBoundaryList.size()); i++) {
    tmpBoundaryList[i].clear();
  tmpBoundaryList.clear();
  try{
    GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
    // for each outer ring create a CoordinateList and add all the points to it
    for(i=0; i< static_cast<int>(ptPolygons.size()); i++) {
      CoordinateList *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
      boundaryList bl = ptPolygons[i];
      boundary b = bl[0];
      cout << "Polygon " << i << endl;
      for(k=0; k< static_cast<int>(b.size()); k++) {
        cout << "Added point " << b[k].x << ',' << b[k].y << endl;
        cl1->add(*(new Coordinate(b[k].x,b[k].y)));
      // for each hole create a coordinate list like above, create a polygon and add to a Geometry vector
      for(j=1; j< static_cast<int>(bl.size()); j++) {
        cout << "Hole " << j << endl;
        boundary b = bl[j];
        CoordinateList *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
          cl2->add(*(new Coordinate(b[k].x,b[k].y)));
        cout << "Creating polygon for hole " << j << ": " << cl2->toString() << endl;
        Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl2),NULL);
        cout << "Geometry " << j << " : " << geom1->toString() << endl;
        holes.push_back(geom1);
        delete cl2;
      // create a polygon from the 1st CoordinateList and the holes
      cout << "Creating polygon " << i << ": " << cl1->toString() << endl;
      Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl1),&holes);
      cout << "test " << endl;
      cout << "Geometry " << i << " : " << geom2->toString() << endl;
      // save this polygon in another vector
      cout << "Adding polygon " << i << endl;
      polygons.push_back(geom2);
      delete cl1;
    cout << "Creating multi-polygon" << endl;
    // when all done create a MultiPolygon object
    Geometry *geom3=gf->createMultiPolygon(&polygons);
    cout << "Creating string" << endl;
    resStr = geom3->toString();
    //clean up
    delete geom3;
    delete gf;
  catch (GEOSException *ge) {
    cout << "ERROR: " << ge->toString() << endl;
  cout << resStr << endl;
-----Original Message-----
Sent: 28 June 2004 11:28
To: GEOS Development List
Subject: Re: [geos-devel] Problems creating polygons with holes
Can you produce a neter code exploiting the bug ?
I mean a .cpp file I can compile and run and debug :)
-strk;
On Mon, Jun 28, 2004 at 11:05:22AM +0100, Darren Carman wrote:
> defs:
>   double x;
>   double y;
> class members used:
>   string tmpStr;
>   string errMsg;
> class function:
> string c_polygon_gml::WKTString(void) {
>   TRACE_FUNC("c_polygon_gml::WKTString");
>   int i,j,k;
>   string resStr = "";
>   try{
>       boundary b = bl[0];
>       TRACE_OUTPUT("Polygon " << i);
>         TRACE_OUTPUT("Added point " << b[k].x << ',' << b[k].y);
>         TRACE_OUTPUT("Hole " << j);
>         boundary b = bl[j];
>         TRACE_OUTPUT("Creating polygon for hole " << j << ": " << cl2->toString());
>         TRACE_OUTPUT("Geometry " << j << " : " << geom1->toString());
>         delete cl2;
>       TRACE_OUTPUT("Creating polygon " << i << ": " << cl1->toString());
>       TRACE_OUTPUT("test ");
>       TRACE_OUTPUT("Geometry " << i << " : " << geom2->toString());
>       TRACE_OUTPUT("Adding polygon " << i);
>       delete cl1;
>     TRACE_OUTPUT("Creating multi-polygon");
>     TRACE_OUTPUT("Creating string");
>     //clean up
>     delete geom3;
>     delete gf;
>     errMsg = ge->toString();
>   return resStr;
> XML read in by class and stored in ptPolygons:
> <?xml version="1.0" encoding="UTF-8"?>
> <AreaDefinition>
> <GDSRequest>
> <query>
> <AreaQuery outputContent="public">
> <queryArea>
> <Polygon srsName="osgb:BNG">
> <outerBoundaryIs>
> <LinearRing>
> <coordinates>
> 339252,1019302
> 339252,1029077
> 348752,1029077
> 346102,1019653
> 339252,1019302
> </coordinates>
> </LinearRing>
> </outerBoundaryIs>
> <innerBoundaryIs>
> <LinearRing>
> <coordinates>
> 340000,1020000
> 340000,1021000
> 341000,1021000
> 341000,1020000
> 340000,1020000
> </coordinates>
> </LinearRing>
> </innerBoundaryIs>
> </Polygon>
> </queryArea>
> </AreaQuery>
> </query>
> </GDSRequest>
> </AreaDefinition>
> Output:
> TR: TRACE ENTRY:c_polygon_gml::WKTString line 168 file c_polygon_gml.cpp
> TR:   Polygon 0
> TR:   Added point 339252,1.0193e+06
> TR:   Added point 339252,1.02908e+06
> TR:   Added point 348752,1.02908e+06
> TR:   Added point 346102,1.01965e+06
> TR:   Hole 1
> TR:   Added point 340000,1.02e+06
> TR:   Added point 340000,1.021e+06
> TR:   Added point 341000,1.021e+06
> TR:   Added point 341000,1.02e+06
> TR:   Creating polygon for hole 1: (340000,1.02e+06,1.7e-308) (340000,1.021e+06,1.7e-308) (341000,1.021e+06,1.7e-308) (341000,1.02e+06,1.7e-308) (340000,1.02e+06,1.7e-308)
> TR:   Geometry 1 : POLYGON ((340000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1020000.0000000000000000))
> TR:   Creating polygon 0: (339252,1.0193e+06,1.7e-308) (339252,1.02908e+06,1.7e-308) (348752,1.02908e+06,1.7e-308) (346102,1.01965e+06,1.7e-308) (339252,1.0193e+06,1.7e-308)
> TR:   test
> Segmentation fault
> Output when the hole is removed:
> TR:   Polygon 0
> TR:   test
> TR:   Geometry 0 : POLYGON ((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000))
> TR:   Adding polygon 0
> TR:   Creating multi-polygon
> TR:   Creating string
> TR: TRACE EXIT:c_polygon_gml::WKTString
> ERROR:
> WTF format
> MULTIPOLYGON (((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000)))
> From: strk [mailto:strk at keybit.net]
> Sent: 28 June 2004 11:01
> Can you send the test code ?
> There are currently no known bug ...
> --strk;
> On Mon, Jun 28, 2004 at 10:15:45AM +0100, Darren Carman wrote:
> > Hi all,
> > I am creating polygons with holes and want to use geos to allow me to output them in WKT.
> > A polygon without a hole works fine, but as soon as I add a hole I get a segmentation fault after calling the createPolygon function (GeometryFactory) and trying to run toString on that polygon.
> > I am using version 1.0.
> > I have tried getting the latest version from CVS but this causes a segmentation fault to occur while adding the 5th polygon coordinate to the CoordinateList (there are only 4 coordinates in the test polygon, the 5th being the first one repeated - I tried making it 6 to see if it was a problem with closing the polygon but I still got a segmentation fault while adding the 5th).
> > Is there a fix for this, or has anyone come accross it?
> > Thanks in advance,
> > Darren
> > "The information in this e-mail and any attachment is confidential and may be privileged. If you have received this e-mail in error, please delete it immediately and destroy any copies on your system. You should not retain, copy or use this e-mail for any purpose, nor disclose all or any part of its content to any other person.
> > Opinions expressed in this e-mail may not be endorsed by the company and unless explicitly indicated, this e-mail shall not form part of any binding agreement".
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
