[geos-devel] Problems creating polygons with holes
strk strk at keybit.net
Wed Jun 30 08:12:19 EDT 2004
        LinearRing *lin1=(LinearRing*)gf->createPolygon(gf->createLinearRing(cl2),NULL);
        cout << "Geometry " << j << " : " << lin1->toString() << endl;
        holes->push_back(lin1);
What is this ? Holes must be a vector of LinearRing.
Your lin1 is not really a LinearRing, you cheated with static-cast!
It's a Polygon...
--strk;
On Wed, Jun 30, 2004 at 08:31:52AM +0100, Darren Carman wrote:
> > The code I've sent you was not intended to work.
> > Please send another 'clean' and buildable example of your work.
> I have left control of the objects with geos, so havent bothered using ->clone(). I only have 1 polygon with 1 hole. If others have this working then I guess I am doing something stupid, but honestly cannot see it.
> I'm not sure how relevant it is, but thought I should mention that i'm using Red Hat Advanced Server OS.
> #include <geos/io.h>
> #include <geos/geom.h>
> using namespace std;
> using namespace geos;
> typedef struct boundaryPt {
>   double x;
>   double y;
> typedef vector<boundaryPt>    boundary;
> typedef vector<boundary>      boundaryList;
> typedef vector<boundaryList>  polygonList;
> void createPolys(polygonList &polys) {
>   int i;
>   boundaryPt poly1[5];
>   boundaryPt hole1[5];
>   boundary tmpBoundary;
>   boundaryList tmpBoundaryList;
>   polygonList ptPolygons;
>   poly1[0].x = 339252; poly1[0].y = 1019302;
>   poly1[1].x = 339252; poly1[1].y = 1029077;
>   poly1[2].x = 348752; poly1[2].y = 1029077;
>   poly1[3].x = 346102; poly1[3].y = 1019653;
>   poly1[4].x = 339252; poly1[4].y = 1019302;
>   hole1[0].x = 340000; hole1[0].y = 1020000;
>   hole1[1].x = 340000; hole1[1].y = 1021000;
>   hole1[2].x = 341000; hole1[2].y = 1021000;
>   hole1[3].x = 341000; hole1[3].y = 1020000;
>   hole1[4].x = 340000; hole1[4].y = 1020000;
>   for (i=0; i<5; i++) {
>     tmpBoundary.push_back(poly1[i]);
>   tmpBoundaryList.push_back(tmpBoundary);
>   tmpBoundary.clear();
>     tmpBoundary.push_back(hole1[i]);
>   polys.push_back(tmpBoundaryList);
>   for(int i=0; i< static_cast<int>(tmpBoundaryList.size()); i++) {
>     tmpBoundaryList[i].clear();
>   tmpBoundaryList.clear();
> int main(int argc, char *argv[]) {
>   vector<LinearRing *> *polygons;
>   vector<LinearRing *> *holes;
>   int i,j,k;
>   string resStr = "";
>   createPolys(ptPolygons);
>   try{
>     GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
>     // for each outer ring create a CoordinateList and add all the points to it
>     polygons = new vector<LinearRing *>();
>     for(i=0; i< static_cast<int>(ptPolygons.size()); i++) {
>       CoordinateList *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
>       boundaryList bl = ptPolygons[i];
>       boundary b = bl[0];
>       cout << "Polygon " << i << endl;
>       for(k=0; k< static_cast<int>(b.size()); k++) {
>         cout << "Added point " << b[k].x << ',' << b[k].y << endl;
>         cl1->add(*(new Coordinate(b[k].x,b[k].y,0.0)));
>       // for each hole create a coordinate list like above, create a polygon and add to a Geometry vector
>       holes = new vector<LinearRing *>();
>       for(j=1; j< static_cast<int>(bl.size()); j++) {
>         cout << "Hole " << j << endl;
>         boundary b = bl[j];
>         CoordinateList *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
>           cl2->add(*(new Coordinate(b[k].x,b[k].y,0.0)));
>         cout << "Creating polygon for hole " << j << ": " << cl2->toString() << endl;
>         LinearRing *lin1=(LinearRing *)gf->createPolygon(gf->createLinearRing(cl2),NULL);
>         delete cl2;
>       // create a polygon from the 1st CoordinateList and the holes
>       cout << "Creating polygon " << i << ": " << cl1->toString() << endl;
>       LinearRing *lin2=(LinearRing *)gf->createPolygon(gf->createLinearRing(cl1),(vector<Geometry *> *)holes);
>       cout << "test " << endl;
>       cout << "Geometry " << i << " : " << lin2->toString() << endl;
>       // save this polygon in another vector
>       cout << "Adding polygon " << i << endl;
>       polygons->push_back(lin2);
>       delete cl1;
>     cout << "Creating multi-polygon" << endl;
>     // when all done create a MultiPolygon object
>     Geometry *lin3=gf->createMultiPolygon((vector<Geometry *> *)polygons);
>     cout << "Creating string" << endl;
>     resStr = lin3->toString();
>     //clean up
>     delete lin3;
>     delete gf;
>   catch (GEOSException *ge) {
>     cout << "ERROR: " << ge->toString() << endl;
>   cout << resStr << endl;
> > GEOS-CVS is not ABI-compatible with GEOS-1.0
> > You have to re-compile your test code.
> > Please let me know.
> I did re-compile my code after make install on the geos CVS library, so i'm not too sure what you mean here.
> Thanks,
> Darren
> -----Original Message-----
> From: strk [mailto:strk at keybit.net]
> Sent: 29 June 2004 23:54
> To: Darren Carman
> Cc: GEOS Development List
> Subject: Re: [geos-devel] Problems creating polygons with holes
> On Tue, Jun 29, 2004 at 10:37:01AM +0100, Darren Carman wrote:
> > Sorry, it didnt work - I forgot that I had commented out the hole initialisation in my code.
> > I changed your code below to use LinearRings (for geom1, geom2 and geom3) as well and saw the seg fault while calling toString on geom3 (as happens in my code). Again no seg fault is seen when no hole is supplied (it also works with geom1-3 as Geometry * when no hole is supplied).
> > So I am still at a loss.
> > Maybe it would help if I could get the cvs version to work - I do the following:
> > ./autogen.sh                                 --> as no configure there
> > ./configure --prefix=$HOME/<path>/           --> lib is used locally, not globally
> > make
> > make install
> > then when I make and run the test program I get the following:
> > ./test_bug: relocation error: ./test_bug: undefined symbol: _ZNK4geos15GeometryFactory16createLinearRingEPNS_14CoordinateListE
> Please let me know.
> --strk;
> > Thanks,
> > Darren
> > Sent: 28 June 2004 21:37
> > To: Darren Carman; GEOS Development List
> > Cc: Paul Ramsey; Yury A. Bychkov
> > Ok. I've found the bug.
> > It is in your code (and in GEOS not handling it).
> > Main problem: you push a Polygon in the holes vector.
> > This - although defined as a Geometry vector - is indeed a LinearRing
> > vector, failing to enforce this typing does result in segfault
> > (not checked in Polygon.cpp).
> > Sub-problem1: your holes vector is an automatic variable, so it
> > is deleted when the code exits the block it is defined in.
> > The Polygon constructor copy the vector pointer and will delete it
> > at Polygon destructio time (I'd change this).
> > Sub-problem2: if I understood your code you are pushing in the
> > holes vector the geometries you previously created, with no cloning.
> > Again the Polygon constructor will take ownership of them (which should
> > be LinearRing) so you should ->clone() them before adding to the vector.
> > My proposal: make Polygon contructor deep copy shell and holes checking
> > for holes type to be LinearRing.
> > A question: why isn't holes a vector <LinearRing *> * ?
> > A note: I did not update CVS... I'd like to hear about my proposal first.
> > --strk;
> > On Mon, Jun 28, 2004 at 09:58:54PM +0200, strk wrote:
> > > I could not find the problem.
> > > Here is a reduced code exploiting the error.
> > > I'll keep inspecting this...
> > > BTW: I don't feel comportable in Polygon constructor taking
> > > ownership of passed arguments, what people think about modifying
> > > this as well ?
> > > --strk;
> > > //--------------------------8<-------------------
> > > #include <geos/util.h>
> > >         Coordinate c;
> > >         CoordinateList *cl1 = CoordinateListFactory::internalFactory->createCoordinateList();
> > >         CoordinateList *cl2 = CoordinateListFactory::internalFactory->createCoordinateList();
> > >         c.x = 339252; c.y = 1019302; cl1->add(c);
> > >         c.x = 339252; c.y = 1029077; cl1->add(c);
> > >         c.x = 348752; c.y = 1029077; cl1->add(c);
> > >         c.x = 346102; c.y = 1019653; cl1->add(c);
> > >         c.x = 340000; c.y = 1020000; cl2->add(c);
> > >         c.x = 340000; c.y = 1021000; cl2->add(c);
> > >         c.x = 341000; c.y = 1021000; cl2->add(c);
> > >         c.x = 341000; c.y = 1020000; cl2->add(c);
> > >         try {
> > >                 Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl1),NULL);
> > >                 cout<<"geom1: "<<geom1->toString()<<endl;
> > >                 Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl2),NULL);
> > >                 cout<<"geom2: "<<geom2->toString()<<endl;
> > >                 vector<Geometry*>*holes = new vector<Geometry*>(1);
> > >                 (*holes)[0] = geom2->clone();
> > >                 Geometry *geom3=gf->createPolygon(gf->createLinearRing(cl1),holes);
> > >                 cout<<"geom3: "<<geom3->toString()<<endl;
> > >                 delete cl1;
> > >                 delete cl2;
> > >         } catch (GEOSException *ge) {
> > >         } catch (...) {
> > >                 cout << "generic ERROR" << endl;
> > > >   double x;
> > > >   double y;
> > > >   vector<Geometry *> polygons;
> > > >   vector<Geometry *> holes;
> > > >   int i,j,k;
> > > >   string resStr = "";
> > > >   ptPolygons.push_back(tmpBoundaryList);
> > > >   try{
> > > >       boundary b = bl[0];
> > > >         cl1->add(*(new Coordinate(b[k].x,b[k].y)));
> > > >         boundary b = bl[j];
> > > >           cl2->add(*(new Coordinate(b[k].x,b[k].y)));
> > > >         Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl2),NULL);
> > > >         cout << "Geometry " << j << " : " << geom1->toString() << endl;
> > > >         holes.push_back(geom1);
> > > >         delete cl2;
> > > >       Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl1),&holes);
> > > >       cout << "Geometry " << i << " : " << geom2->toString() << endl;
> > > >       polygons.push_back(geom2);
> > > >       delete cl1;
> > > >     Geometry *geom3=gf->createMultiPolygon(&polygons);
> > > >     resStr = geom3->toString();
> > > >     //clean up
> > > >     delete geom3;
> > > >     delete gf;
> > > > Sent: 28 June 2004 11:28
> > > > To: GEOS Development List
> > > > Can you produce a neter code exploiting the bug ?
> > > > I mean a .cpp file I can compile and run and debug :)
> > > > -strk;
> > > > On Mon, Jun 28, 2004 at 11:05:22AM +0100, Darren Carman wrote:
> > > > > defs:
> > > > >   double x;
> > > > >   double y;
> > > > > class members used:
> > > > >   string tmpStr;
> > > > >   string errMsg;
> > > > > class function:
> > > > > string c_polygon_gml::WKTString(void) {
> > > > >   TRACE_FUNC("c_polygon_gml::WKTString");
> > > > >   int i,j,k;
> > > > >   string resStr = "";
> > > > >   try{
> > > > >       boundary b = bl[0];
> > > > >       TRACE_OUTPUT("Polygon " << i);
> > > > >         TRACE_OUTPUT("Added point " << b[k].x << ',' << b[k].y);
> > > > >         TRACE_OUTPUT("Hole " << j);
> > > > >         boundary b = bl[j];
> > > > >         TRACE_OUTPUT("Creating polygon for hole " << j << ": " << cl2->toString());
> > > > >         TRACE_OUTPUT("Geometry " << j << " : " << geom1->toString());
> > > > >         delete cl2;
> > > > >       TRACE_OUTPUT("Creating polygon " << i << ": " << cl1->toString());
> > > > >       TRACE_OUTPUT("test ");
> > > > >       TRACE_OUTPUT("Geometry " << i << " : " << geom2->toString());
> > > > >       TRACE_OUTPUT("Adding polygon " << i);
> > > > >       delete cl1;
> > > > >     TRACE_OUTPUT("Creating multi-polygon");
> > > > >     TRACE_OUTPUT("Creating string");
> > > > >     //clean up
> > > > >     delete geom3;
> > > > >     delete gf;
> > > > >     errMsg = ge->toString();
> > > > >   return resStr;
> > > > > XML read in by class and stored in ptPolygons:
> > > > > <?xml version="1.0" encoding="UTF-8"?>
> > > > > <AreaDefinition>
> > > > > <GDSRequest>
> > > > > <query>
> > > > > <AreaQuery outputContent="public">
> > > > > <queryArea>
> > > > > <Polygon srsName="osgb:BNG">
> > > > > <outerBoundaryIs>
> > > > > <LinearRing>
> > > > > <coordinates>
> > > > > 339252,1019302
> > > > > 339252,1029077
> > > > > 348752,1029077
> > > > > 346102,1019653
> > > > > 339252,1019302
> > > > > </coordinates>
> > > > > </LinearRing>
> > > > > </outerBoundaryIs>
> > > > > <innerBoundaryIs>
> > > > > <LinearRing>
> > > > > <coordinates>
> > > > > 340000,1020000
> > > > > 340000,1021000
> > > > > 341000,1021000
> > > > > 341000,1020000
> > > > > 340000,1020000
> > > > > </coordinates>
> > > > > </LinearRing>
> > > > > </innerBoundaryIs>
> > > > > </Polygon>
> > > > > </queryArea>
> > > > > </AreaQuery>
> > > > > </query>
> > > > > </GDSRequest>
> > > > > </AreaDefinition>
> > > > > Output:
> > > > > TR: TRACE ENTRY:c_polygon_gml::WKTString line 168 file c_polygon_gml.cpp
> > > > > TR:   Polygon 0
> > > > > TR:   Added point 339252,1.0193e+06
> > > > > TR:   Added point 339252,1.02908e+06
> > > > > TR:   Added point 348752,1.02908e+06
> > > > > TR:   Added point 346102,1.01965e+06
> > > > > TR:   Hole 1
> > > > > TR:   Added point 340000,1.02e+06
> > > > > TR:   Added point 340000,1.021e+06
> > > > > TR:   Added point 341000,1.021e+06
> > > > > TR:   Added point 341000,1.02e+06
> > > > > TR:   Creating polygon for hole 1: (340000,1.02e+06,1.7e-308) (340000,1.021e+06,1.7e-308) (341000,1.021e+06,1.7e-308) (341000,1.02e+06,1.7e-308) (340000,1.02e+06,1.7e-308)
> > > > > TR:   Geometry 1 : POLYGON ((340000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1020000.0000000000000000))
> > > > > TR:   Creating polygon 0: (339252,1.0193e+06,1.7e-308) (339252,1.02908e+06,1.7e-308) (348752,1.02908e+06,1.7e-308) (346102,1.01965e+06,1.7e-308) (339252,1.0193e+06,1.7e-308)
> > > > > TR:   test
> > > > > Segmentation fault
> > > > > Output when the hole is removed:
> > > > > TR:   Polygon 0
> > > > > TR:   test
> > > > > TR:   Geometry 0 : POLYGON ((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000))
> > > > > TR:   Adding polygon 0
> > > > > TR:   Creating multi-polygon
> > > > > TR:   Creating string
> > > > > TR: TRACE EXIT:c_polygon_gml::WKTString
> > > > > ERROR:
> > > > > WTF format
> > > > > MULTIPOLYGON (((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000)))
> > > > > Sent: 28 June 2004 11:01
> > > > > Can you send the test code ?
> > > > > There are currently no known bug ...
> > > > > --strk;
> > > > > On Mon, Jun 28, 2004 at 10:15:45AM +0100, Darren Carman wrote:
> > > > > > Hi all,
> > > > > > I am creating polygons with holes and want to use geos to allow me to output them in WKT.
> > > > > > A polygon without a hole works fine, but as soon as I add a hole I get a segmentation fault after calling the createPolygon function (GeometryFactory) and trying to run toString on that polygon.
> > > > > > I am using version 1.0.
> > > > > > I have tried getting the latest version from CVS but this causes a segmentation fault to occur while adding the 5th polygon coordinate to the CoordinateList (there are only 4 coordinates in the test polygon, the 5th being the first one repeated - I tried making it 6 to see if it was a problem with closing the polygon but I still got a segmentation fault while adding the 5th).
> > > > > > Is there a fix for this, or has anyone come accross it?
> > > > > > Thanks in advance,
> > > > > > Darren
> > > > > > "The information in this e-mail and any attachment is confidential and may be privileged. If you have received this e-mail in error, please delete it immediately and destroy any copies on your system. You should not retain, copy or use this e-mail for any purpose, nor disclose all or any part of its content to any other person.
> > > > > > Opinions expressed in this e-mail may not be endorsed by the company and unless explicitly indicated, this e-mail shall not form part of any binding agreement".
> > > > > > _______________________________________________
> > > > > > geos-devel mailing list
> > > > > > geos-devel at geos.refractions.net
> > > > > > http://geos.refractions.net/mailman/listinfo/geos-devel
