[geos-devel] buffer bug fixed
Martin Davis mbdavis at VividSolutions.com
Wed May 19 20:57:21 EDT 2004
I don't think so...  We've sort of outstripped the ability to express
tests in .xml format  (e.g. buffer tests are really possible to
express).
There is a bunch of Junit buffer tests - would those be useful?
By the way, do all the tests which uncovered bugs in GEOS pass in JTS?
If not, can you send me the tests?
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: strk [mailto:strk at keybit.net]
> Sent: May 19, 2004 10:00 AM
> To: geos-devel at geos.refractions.net
> Cc: Martin Davis; Paul Ramsey
> Subject: [geos-devel] buffer bug fixed
> I've found and fixed a bug in BufferOp.
> example.cpp runs work now fine on buffers.
> There is an issue left with intersection,
> where side location conflict TopologyException is raised.
> Still we have no failures on .xml tests, apart from the
> 5 isValid tests also failing with JTS-1.4
> Martin, could you provide any new-features .xml tests ?
> --strk;
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
