[geos-devel] build problem on Solaris
strk at refractions.net strk at refractions.net
Fri Nov 19 09:28:29 EST 2004
On Fri, Nov 19, 2004 at 09:28:21AM -0500, Norman Vine wrote:
> Jan Kolar writes:
> > after adding the macro to 'platform.h' the exit point has changed, however
> > compilation still unsuccessful.
> > ../operation/valid/IsValidOp.cpp:63: error: `isinf' undeclared
> maybe this will help
> http://www.unixguide.net/sun/faq/5.06.shtml
> note: google is your friend  :-)
> hint: google("solaris isinf")
Good stuff. This means you can also remove that macro...
--strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
