[geos-devel] geos in Pythoon
Sean Gillies sgillies at frii.com
Fri Oct 15 09:28:34 EDT 2004
On Oct 15, 2004, at 4:34 AM, Niki Spahiev wrote:
> On Fri, 15 Oct 2004 11:03:53 +0200, strk at refractions.net
> <strk at refractions.net> wrote:
>> If you don't see a swig/ directory in that package this means
>> the SWIG part did not handle to go in 2.0.1 distribution.
>> Pull down a CVS snapshot to take a look at it.
> http://geos.refractions.net/geos-cvs.tar.bz2 has no swig files as well.
Niki,
You may have to pull it directly from CVS if it is not in the
nightly snapshot.  I've also got it available from my own website
until the situation is corrected
   http://users.frii.com/sgillies/projects/geos-swig.tgz
Download, copy into your GEOS directory and extract.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
