[geos-devel] setup.py for Python SWIG wrappers
Sean Gillies sgillies at frii.com
Fri Apr 8 10:46:51 EDT 2005
On Apr 5, 2005, at 6:00 AM, Niki Spahiev wrote:
>> On Apr 4, 2005, at 8:58 AM, Niki Spahiev wrote:
>>> Not very good.
>>> sys.platform == 'win32' does not mean using MSVC.
>>> GCC on win32 is not compatible with this patch
>> Let's try to get this fixed soon.  It seems to me that the 'win32'
>> platform should be understood to be the default windows builds of
>> Python using VC6 (Python <2.3) or MSVC .NET (Python 2.4).  This will
>> be
>> the environment of the great majority of windows users, yes?
>> Evidently
>> the sys module can't distinguish between these and a custom GCC
>> Python.
>>   Any ideas?
> There is no GCC Python. GCC (mingw) compiles modules for standard
> win32 python.
> Niki Spahiev
OK, now I understand.  This will be tricky.  How to detect which
compiler is going to be used on windows?  If the compiler were
specified on the command line like
     python setup.py build --compiler=mingw
it would be easy, just sys.argv[2].  But if users are specifying the
compiler in a setup.cfg file, then this doesn't work and the compiler
isn't even set until the build target is evaluated.
Any ideas, Niki?
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
