[geos-devel] GEOS Exceptions
Frank Warmerdam fwarmerdam at gmail.com
Mon Apr 18 11:16:45 EDT 2005
Folks,
I must confess I am not a particular advanced C++ programmer.  I
tend to avoid use of C++ exceptions, so now I find myself in a situation
where I am not quite sure what to do.
I have the following code to parse a WKT string into a
geos geometry.
    try
        geos::Geometry *geosGeometry = NULL;
        geosGeometry = geosWktReader.read( oWKT );
        return geosGeometry;
    catch( geos::GEOSException &e )
        CPLError( CE_Failure, CPLE_AppDefined,
                  "GEOSException: %s",
                  e.toString().c_str() );
        return NULL;
The WKT in this case is invalid (a two point polygon) that looks
like this:
POLYGON ((428909.103 4756578.350,681115.834 4980288.650))
Geos seems to throw an exception, but my catch does not seem
to be catching it.  I skimmed through the WKTReader code, and
I see it mostly throws ParseExceptions which are derived from
GEOSException.  However, I suspect the exception that really
gets thrown is at a lower validation level.
Is anyone aware of exceptions that GEOS might throw in this
case that are not derived from geos::GEOSException?
Should my try/catch block catch all geos exceptions properly?
Does anyone know an easy way to break in any exception
as it is thrown in gdb?
Best regards,
