[geos-devel] GEOS Exceptions
strk at refractions.net strk at refractions.net
Tue Apr 19 12:40:34 EDT 2005
On Tue, Apr 19, 2005 at 09:34:11AM -0700, Chris Hodgson wrote:
> >In section 8.3 they have an EMPTY value, something like this:
> >PRIMARY
> > = OPTIONAL SEQUENCE / REPEATED SEQUENCE
> > / SPECIAL SEQUENCE / GROUPED SEQUENCE
> > / META IDENTIFIER / TERMINAL / EMPTY.
> >EMPTY = .
> If the spec says this as quoted above, then this does in fact mean that
> EMPTY means nothing.
> It literally says, EMPTY equals nothing, period. I haven't looked at the
> rest of the spec, but there's nothing ambiguous about it here, IMHO.
That's not OGC SFS spec, but an example in the EBFN spec.
I think you're right here because EMPTY is defined.
OGS SFS does not define EMPTY, and use <bracketed> strings
for defined things.
--strk;
